Liebherr CUN 3033 fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr CUN 3033 fault
  • #88938
    matt343
    I hope somebody can help I have a Liebherr CUN 3033 index 21d/147.
    Over the past month or so it has started beeping with a flashing super frost button.
    It beeps 3 at a time whilst flashing the number 3 bar on the led display. The super frost button flashes green.
    I have tried a complete power down for 24 hours which fixed the problem for a short while however it has returned. If its left alone it will fix its self however it will randomly return.
    Matt
    #439839
    Tony R
    Re: Liebherr CUN 3033 fault
    This indicates failure of the fridge evaporator sensor part 9590206 is needed.
    Tony.
    http://www.liebherr-randallrefrigeration.co.uk/
    #439840
    davesinclair
    Matt / Tony,
    I have exactly the same fault on my Liebherr CUN 3033. Is the above sensor all that is required ( did it fix the fault?) and what is the cost of the part?
