Liebherr CUN3033
  • #88453
    char14lew
    hi guys,has anyone come across this problem with these f/freezers?it’s had the evaporator sensor changed due to intermittent warning of fridge and freezer.Now the freezer seems ok but only the bottom half and door of the fridge are cold.The super frost button was put on when started up again and is still flashing along with the temp guage at 5.The system seems to be making quite a bit of groaning.Other posts suggest changing the pcb but could it be a gas problem?
    thanks
    Darrell
    #438147
    ELDAR59
    Re: Liebherr CUN3033
    Hello, you say the superfrost button is flashing? This indicates a sensor fault.
    Which evaporator sensor was changed, do you know?
    #438148
    char14lew
    the evaporator sensor was changed mate!
    thanks
    #438149
    char14lew
    sorry,didn’t read your post properly! the white evaporator sensor that runs down the side and to the bottom.
    thanks
    #438150
    ELDAR59
    The freezer evaporator sensor then?
    I’d try the fridge evaporator sensor.
