Liebherr CUNesf over cooling and error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Liebherr CUNesf over cooling and error code
  • #79584
    DDA
    have a customer that has a Liebherr CUNesf3903 over cooling (fridge is frozen)and showing an error code.
    i have looked on the guide but doesn’t have the displayed code listed.
    the fridge is occasionally beeping 4 times.
    the display shows 7 and 5 lights
    there seems to be one of the plugs on the pcb that has no be an o/c but didn’t want to go any further until i researched the error.
    can anyone help.
    many thanks
    #409856
    Quick-Tech
    Re: Liebherr CUNesf over cooling and error code
    evap sensor is the most common thing on these, but if it beeps 4 times that means door is open, if it beeps 3 time it means temperature not correct.
    #409857
    DDA
    the fridge seems to beep 3 times for the door and is beeping 4 times when not open. ill try the sensor and go from there.
    cheers for the help.
    #409858
    ELDAR59
    Hello, the alarm will beep three times for the door and four for a temp alarm.
    I’d be looking at the fridge evaporator sensor.
    Is the freezer ok?
    #409859
    DDA
    Just an update,
    i was unable to resolve this as there was a PCB fault or a gas valve fault so advised customer to approach manufacturers.
    Liebherr where extremely help full and even supplied me with service manuals for this unit.
    thanks for the advice all
    Anthony
