Liebherr CUNESF3903 freezer fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr CUNESF3903 freezer fault
  • #79963
    vellawatcher
    Liebherr Fridge freezer not working correctly.
    Fridge good holding at 5degrees, freezer not cooling at all. Any ideas?
    Neil
    #411201
    vellawatcher
    Re: Liebherr CUNESF3903 freezer fault
    Bit of an update.
    Overnight the freezer cooled down (not to temperature but cold). Fridge warmed up to almost ambient temp. The LED indicators are now showing 5 (constant) and 1 (flashing).
    Yesterday I’m sure the LED indicators were showing 9 and 5 which I thought was the evap. sensor but now I have no idea.
    Any thoughts?
    #411202
    vellawatcher
    Got the LEDs wrong, 1 constant, 5 flashing
    #411203
    ELDAR59
    Hello, is the super frost light flashing too?
    #411204
    vellawatcher
    ot normally, but if I press the button, it flashes. Does that help?
    #411205
    vellawatcher
    Should read NOT normally, unless I press it. Then it will flash
    #411206
    ELDAR59
    Is it still warm in the fridge?
    If so, then it’s engineer time I’m afraid. This doesn’t sound like a simple one.
    #411207
    vellawatcher
    Yes its still warm. Know a good engineer in Hampshire?
    #411208
    ELDAR59
    I do actually. ill come back to you with his details.
