Hi all, I need a door seal for Liebherr fridge freezer model CUP-2221. For the lower freezer section. Service number is 0908948-00.
I tried a google search, but it brings up many unhelpful shops which don’t give any model compatibility details. Many thanks
The reason model numbers are not listed is, it’s very, very easy to get these wrong if you don’t know what you’re doing. It is not a thing that lends itself to self-service by any stretch.
Your freezer door seal is bonded as 3 parts, The door, liner and gasket, the replacement seal is not an easy fix. The door has to be removed and placed on a flat surface.
The old seal has to be cut off close to the liner, a gap has to be made under the liner edge to slot in the new door seal and then secured with 30 screws, there is no stock at present in the UK but is available once ordered, Part number 7108866.
Regards, Tony.
