Re: Liebherr error codes for SWTNes3010
Hi mate, it’s not giving you a fault code though is it?
You’ll need to find out if the compressor will run or not.
Try pressing the up button and the off button at the same time, that should put you into the service menu.
Toggle the up button till you get the ‘L’ menu. Select that and see if the compressor will run.
If it runs, the the fault will be down to the control, ie sensor or pcb.
Getting into the ‘E’ menu should give you the value that the sensors are reading. If one of these is way out, then that could very well be your problem.
