Has anyone got any info on a Liebherr FF 3056 23f/001 please?
I’ve never done any work on these and they say the freezer fan is making a lot of noise and the fridge isn’t working too well.
I’m assuming it’s a defrost heater or sensor.
They’re defrosting it at the mo and I’m going to look at it tomorrow, is there a diagnostics mode or a way of reading the fault codes?
hi Dave , ive seen a few o these , dont know if your one is the same but they have sensor and pcb problems also , the evap sensor should be located on the back wall pushed into the side of the evap assembly , make sure the digital stat is working turn the dial the led’s change temp . ive had the adjuster knob break off and i couldnt change the values all parts from NAA in dublin
