Liebherr Freezer defrosting/wrong temperature
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr Freezer defrosting/wrong temperature
Viewing 5 posts - 16 through 20 (of 20 total)
  • #466973
    westb182
    kwatt wrote:Result. 😀
    If you or someone else knows how to remove and replace the sensor in the evaporator so I can properly place the new one, I’d really appreciate it. I tried on Sunday, but there is some hard foam cover on it and it seems to go all the way around. I didn’t want to rip it off or damage it. Though, I would guess that having it on the side of the evaporator is also quite effective.
    #466974
    On that diagram item 503 is a “HEXAGON-HEAD SELF-TAPPING SCREW” that would seem to hold it in place.
    westb182
    kwatt wrote:On that diagram item 503 is a “HEXAGON-HEAD SELF-TAPPING SCREW” that would seem to hold it in place.
    Did you mean 530? I can’t seem to find 503.
    530 are the screws (7 of them) that hold the back plastic panel in place that covers the evaporator and rest of the inside components. That’s not the cover on the evaporator. On the evaporator there was a sticker that has part code 5944084-01 (not sure if that helps).
    #466976
    Sorry, yes, typo.
    Do not move the actual evaporator as if you bust a pipe, game over without a refrigeration person with special equipment to fix it.
    westb182
    kwatt wrote:Sorry, yes, typo.
    Yeah, exactly. So I guess for now I’ll just leave it where it is.
