Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Liebherr Freezer Problem
- This topic has 7 replies, 3 voices, and was last updated 11 years, 2 months ago by
ian07.
January 25, 2015 at 5:12 pm #83866
ian07
ParticipantHi,
I have a Liebherr Comfort (Cup3021) Service No:0905886-02
The fridge over Christmas got very cold (stat not touched) iced up bottles of water etc…
Now i have noticed that the freezer,isnt keeping things frozen. There is/was ice in there bit items not frozen (ice lollys just mush)Can anyone trow some light on this for me as ive never had a problem with it before (approx 4-5 yrs)
Cheers
IanJanuary 25, 2015 at 11:50 pm #424022johnthefridge
ParticipantRe: Liebherr Freezer Problem
ian07 wrote:Hi,
Cheers
Ian
Hi Ian , If The Top Fridge Section Has Frozen The Produce & You Have Noticed Also That The Freezer Is Not Reaching -18c, It Could Be Several Items To Check , 1st is the frost even on the back wall fridge section, 2nd can you hear the compressor running continuously , 3rd If the refrigerant (Gas) has started to leak / Block ! these are the classic symptoms , When You Get Back To Me I Will Be Able To Diagnose What Component Has Failed , (This Appliance Is A Simple One Circuit Refrigerant Flowing From The Fresh Food Cabinet & Then Into The Freezer Compartment)john
January 26, 2015 at 5:57 pm #424023ian07
Hi John,
1) The frost seems to be in the upper 1/2 (maybe 1/3) more towards the centre.
2) My wife has been in today & has said it has been running continuously all day.
3) I’m not sure how to check the gas for a leakI hope this helps
Ian
January 26, 2015 at 6:40 pm #424024johnthefridge
Hi Ian , Thanks Getting Back To Me, Ok. . . . The Refrigeration Circuit Could Be Restricted Or Refrigerant (Gas Shortage R600a) Microscopic Leak, Unfortunately I Am Not In Your Area, Liebherr Head Office Will Help You With A Local Authorized Refrigeration Engineer,
These appliances are excellent quality so I would contact Liebherr Uk & explain , if I can be of any other help, or you would like to explain further symptoms just mail me . johnJanuary 26, 2015 at 8:33 pm #424025admin
KeymasterRe: Liebherr Freezer Problem
More likely that its one of the evaporator sensors that has faided.
Bryan
January 26, 2015 at 9:27 pm #424026johnthefridge
Yes r600a it could be a sensor fault on other Liebherr models , but not on this one , this model has the good old fashioned type capillary with a diaphragm / bellows , & both compartments fridge & freezer are statically cooled !. . . . . jm
January 26, 2015 at 10:08 pm #424027admin
I forgot to check ;-@
April 13, 2015 at 8:42 am #424028ian07
I’m still having issues with this FF & need to find a local engineer to come & have a look. Can anyone point me in the direction of one rather than just pot luck from Yellowpages etc
Cheers -
