Liebherr Fridge Compressor Not Running.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr Fridge Compressor Not Running.
  • #16136
    steveshakeshaft
    Hello all, I have a Liebherr Refrigerator Model Number KSVES3660, Serial Number- 0972272-00. It is just over two years old and Liebherr have refused a warranty claim despite it being JUST out of warranty.
    The internal light is working, so the fuse is OK. The fridge is not cooling down at all, the compressor refuses to run. The only knob or switch is a temperature control selector on the front panel. Turning it to full doesn’t start the compressor. Seeing as it is only two years old I don’t believe the compressor will be faulty. So I suspect that the temperature controller has failed. I have found that there is a sensor inside the fridge compartment with what seems to be a capilliary tube running up to the controller/switch but I ran out of time yesterday to strip in down and confirm this.
    I’m thinking I need the capilliary tube and the temperature controller/switch assembly ❓
    Where can I order one ready to fit when I get home one evening please ❓ It seems Liebherr spares aren’t readily available, but surely it is a common part anmd NOT Liebherr exclusive ❓
    Finally, I feel ripped off buying this machine. It cost a fortune and has now failed on me. It seems price is no indicator of quality these days ❓ I threw away on old Scandinova that was a bit rusty but otherwise 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} reliable when I bought the Liebherr.
    Thanks.
    Steve.
    #167666
    Re: Liebherr Fridge Compressor Not Running.
    hi steve
    this thermostat is readily available,in stock,in fact i keep them in stock with leibherr..if you want a genuine one that is with a life span of 2yrs max normally they last 18 mths.
    i fit an alternative thermostat which i have never had a problem with.
    if you want one e-mail me r600a@hotmail.com
    bryan
    #167667
    steveshakeshaft
    Thanks for confirming my suspicions. The OEM parts are cr*p quality then, despite the sky high prices of the fridges. Typical. I should be able to get a non-OEM thermostat locally, if I can’t, I will certainly mail you.
    I have a matching Liebherr Freezer, I might just change the ‘stat in that too as preventive maintenance ❗
    #167668
    dna
    Hi i have one of these aswell can yo u give me th part number for the non oem thermostat please need it urgently customer has baby and no fridge!!!!!
