Liebherr Fridge drawer runner support
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr Fridge drawer runner support
  • #90198
    rjt36
    Hi, could anyone please help me. I need to remove the white plastic fridge runner support from my Liebherr fridge. I have a replacement and can see it isn’t held in by screws. But I can’t figure out how to remove the old one without tearing the internals of the fridge apart?!
    Thank you,
    #444014
    Tony R
    Re: Liebherr Fridge drawer runner support
    Hi, Can you supply model, index and service number and I may be able to advise you.
    http://www.liebherr-randallrefrigeration.co.uk/
    #444015
    rjt36
    It is serial number 26.491.161.6
    Service number 9985666-01
    SKes 4210 index 21a/001
    Hope that might help? Thank you so much.
    #444016
    Tony R
    Once the runner is off, I assume it fell off once the small plastic node had broken.
    The insert in the wall has to be removed with a set of mole grips.
    Clamp the section tightly and lever out in a downward motion. the new is inserted and can tapped in with a rubber mallet. I would advise putting two self tapping screws to hold the runner once slotted back on, this will add strength, as the nodes only break if the main door gets shut against a protruding drawer.
    #444017
    rjt36
    Thank you so much. That’s very helpful.
    Merry Christmas!
