Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Liebherr fridge F2 fault.
- This topic has 18 replies, 5 voices, and was last updated 15 years, 5 months ago by
plug007.
October 25, 2010 at 2:00 am #58260
plug007
ParticipantHello lads first post here. My mothers liebherr fridge has a fault code up, F2.
Liebherr refrigerator
Fault code: F2
Model: KBES 3650
Is that an evaporator sensor or temperature sensor? Do whitegoods sell this part?
cheers!October 25, 2010 at 7:14 am #333887kwatt
KeymasterHi,
Can you give us the service number from the rating plate inside the machine, you need that to look up almost anything.
October 25, 2010 at 2:18 pm #333888plug007
Participant9914726-05 service number. Also that number on the front of the booklet. 7082-212-02.
Liebherr don’t seem to have much customer support, do you find this?
cheers mate, im cracking up with this fridge!
October 25, 2010 at 2:49 pm #333889kwatt
KeymasterRe: Liebherr fridge F2 fault.
It is reporting an error with the refrigerator compartment air sensor.
If you need it, the part is listed HERE
October 25, 2010 at 4:01 pm #333890plug007
ParticipantThank you so so much! Just one thing before I buy it the link you gave me is for a Freezer Air Sensor. I only have a fridge on its own. Maybe its the same part for the fridge too. Anyway your the expert here, not me. Just confirming its the correct part?
Thanks in advance.October 25, 2010 at 4:15 pm #333891kwatt
KeymasterYes, same part.
Can’t guarantee that it will cure the fault though, I can only point you in the direction of what the machine is telling you.
October 25, 2010 at 4:49 pm #333892johnsdad
ParticipantRe: Liebherr fridge F2 fault.
F2 = evaporator sensor fault
October 25, 2010 at 4:56 pm #333893plug007
ParticipantRight thanks lads, so an air sensor is just the same as the evaporator sensor?
cheers!October 25, 2010 at 7:40 pm #333894ELDAR59
hello, just to clear things up here,
F2 = fridge evaporator sensor fault.
the part number that ken supplied you with is the correct part for the sensor repair kit that fits this model.
this part should repair the appliance.
cheers.
October 25, 2010 at 8:18 pm #333895plug007
ParticipantThank you now I can get it, cheers everyone.
Now next up, where about is it located in the fridge, is it behind the back panel inside the fridge? Im not a refrigeration technician but im a mechanic so I should be able to do it once I know the location.
October 25, 2010 at 9:17 pm #333896johnsdad
Part no. 9590088 is more suitable, comes with splicing connector, quite a common fault on Liebherr
October 25, 2010 at 9:25 pm #333897ELDAR59
hi mate, on your fridge there should be three sensors:-
a fridge air sensor, which should have a red tag on it, a bio fresh sensor, which should have a brown tag on it and a fridge evaporator sensor, which should have a green tag on it.
pulling the backplate away carefully (remove the fan connector) will reveal the evaporator.
the sensor will be tucked into a pocket at the bottom of it and the cable will run through a hole in the cabinet behind the evaporator and up to a connector on the pcb.
the sensor you receive is a kit which means you cut the cable and join the new one. full instructions are in the pack.cheers.
October 25, 2010 at 9:27 pm #333898ELDAR59
9590142 has replaced 9590088 and comes in the same kit form.
November 3, 2010 at 8:20 pm #333899plug007
ParticipantHello again.
I ordered it early last week and it has been shipped yesterday as it was not in stock. So I reckon i’ll have it maybe tomorrow or Friday.So what tools will I need? Solder/soldering iron, torx screw drivers, panal/trim remover, ratchets? I don’t want to have to bring the whole tool box home ya know! lol
Alf you say remove the backplate, is that inside the fridge or actually behind the whole fridge?
cheers mate!
November 4, 2010 at 7:54 am #333900ELDAR59
hello, the backplate is inside the fridge.
take all the shelves out and the divider. you’ll see little clips at the side of the backplate. lift these out.
there may also be two T15 torx screws holding the backplate in.
when you pull it out, be careful as the air and bio fresh sensors are still connected to it, as is the fan cable.
disconnect all these and pull out the backplate completely. this will reveal the evaporator.
give the retaining srews at the bottom a quarter of a turn and ease the evaporator forward enough so you can feel where the evap sensor is located and pull it out..
in the kit you will receive are all the instructions. be sure to join the cable OUTSIDE the cabinet at the back and not inside.
tools you will need are T15 torx driver, large flat blade s/d, side cutters and pliers alongside a 7mm socket to partially remove the condenser grill at the back. (this where you join the cables).
cheers. -
