Liebherr Fridge Freezer CUN 3523 20M Error Lights Flash
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr Fridge Freezer CUN 3523 20M Error Lights Flash
  • #96318
    Rob098098
    The SuperFrost button flashes together with the temperature display.
    I have checked that the freezer drain is not blocked nor the fridge drain hole.
    The fridge seems to keep to 5 degrees but has gone up sometimes. The freezer is at -25!
    Is a fault with the tempreture sensor/s?
    I have a multi meter so can check to values of the sensor output.
    If so how do I fit a new one?
    Rob
    #462978
    Tony R
    Hi Rob, what number is the green block flashing with the superfrost ?
    #462979
    Rob098098
    the 5 and 9 are flashing with the superfrost light
    #462980
    Rob098098
    PS. Thank you so much for replying to my question
    #462981
    Tony R
    Hi Rob, the refrigerator evaporator sensor has failed.
    #462982
    Rob098098
    What do I need to do to fix it?
    #462983
    Rob098098
    Where is the sensor. ie the one in the freezer compartment or somewhere else. What is the part no for the replacement etc. Thanks Tony
    #462984
    Tony R
    Hi Rob, there are 2 sensors in the fridge air (red ) Evaporator ( green ) you will need part 9590206 and replace the green one with the kit, it can be bought on Whitegoods parts site.
    #462985
    Rob098098
    Thanks for your help, I will get on with it and will purchase from this site. If I have any further queries I’ll ask. Cheers, Rob
