Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Liebherr fridge Freezer KIKN 3056, error msg F3
- This topic has 10 replies, 2 voices, and was last updated 12 years ago by
cup1959.
March 27, 2014 at 9:57 am #80121
cup1959
ParticipantHi Im talking about a 7 yr old Liebherr Fridge Freezer Type 7082 046-00 KIKN 3056. Firstly, the LCD relating to Freezer section started flashing with no numbers just 2 lines. The fridge was normal showing 5deg. Despite the flashing lines, the freezer seemed to stay normal and cold regardless for about 10 days. BUT just now, the error message F3 came on. The fridge had until this point said 5deg. Now the fridge LCD is blank and the freezer shows F3.
Any clues what this means?
Many Thanks
March 27, 2014 at 8:43 pm #411738ELDAR59
ParticipantRe: Liebherr fridge Freezer KIKN 3056, error msg F3
F3 is the freezer air sensor at fault.
March 28, 2014 at 6:45 pm #411739ELDAR59
do you have the service number of the appliance?
March 29, 2014 at 12:35 am #411740cup1959
Yes
Service number is9985130-05
Very curious what this means. Thanks for your interest!
March 29, 2014 at 3:59 pm #411741ELDAR59
F3 is freezer air sensor. I’ll look online at your appliance, but it will be Monday morning now.
March 29, 2014 at 8:48 pm #411742cup1959
That would be so nice of you. The technician also might be able to come Monday …
March 31, 2014 at 6:30 am #411743ELDAR59
part number for freezer air sensor is 6942118.
March 31, 2014 at 6:43 am #411744cup1959
I had turned the whole thing off over the weekend and started it up again Monday morning as technician was coming. To my amazement, the appliance is now behaving normally. 8 hrs after turning it on, it is almost at normal temp ie 5 for fridg and -15 for freezer. The freezer hopefully will stabilise at -16. Do you think this will be shortlived or could it be that the unit needed a total defrost and rest? And a good clean I might add .. which is the only good thing about emptying it.
Will be interesting to see! Thanks again ELDAR59.
March 31, 2014 at 6:57 am #411745ELDAR59
i’d call off the engineer’s visit, as it could be wasting his time at this point, ie nothing to look at.
you could tell them that you’ll monitor the situation and contact them again when the fault occurs again.
f3 is freezer air sensor fault as already discussed. moisture can get in to the head of the sensor, disrupting the information that the sensor is sending back to the pcb. turning it off could have allowed the moisture to dry, or allowed the electronics to reset and the appliance looks like it’s ok again.
I’d not put all my faith in it straight away and it may well be worth keeping the engineer’s visit and asking him to replace the sensor.
your call really.March 31, 2014 at 7:04 am #411746cup1959
Yes I was able to call off the technician .. and so we ll wait and see. Good start to my week. thanks again! I’ll let you know if it plays up again in case anyone else out there has F3 problem.
April 26, 2014 at 6:10 am #411747cup1959
Thrilled to report after a month of perfect performance, the problem seems to have vanished. It required turning the whole unit off for 48hrs …
Thanks for the support.
