Liebherr fridge k 4270 service 0979128-01
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr fridge k 4270 service 0979128-01
  • #102220
    Hrubin
    1. My Liebherr fridge k 4270 service 0979128-01 stopped to cool the fridge light is working and temperature display as well and showing 20 degrees I checkt the overload and it had some resistance the compressor had more less the 2 bottom the same total as add up top to right and to to left the fan inside didn’t move last time but doesn’t look like that should have the reason for the fridge to get to 20 degrees as well compressor start a quiet sound and after 5 seconds it does a tick and stops it sounds to me that the relay is the broken part but I don’t know how to check it as it is not the normal one where you can check it easily
    2. i would be happy if someone could advise me what can be broken and how to check the relay if it is faulty
    3. thank you
    #487986
    Tony R
    You can not test these compressor PTC relays, if the overload ( klixon ) is cutting out, then it is possible the relay is faulty or it could be the compressor itself, without a specilized hermetic compressor tester to check compressor, your only option is to buy a new relay and see if that resolves your issue.
    Your compressor is an Aspera EMZ26CLC and I believe the relay is available on UK Whitegoods part shop as SKU#2260209040 but please check with them beforehand.
