Re: Liebherr fridge not cold enough
im not sure about sensor mate. id be looking at the system probably. sensor faults are much more common than system faults, granted, but im not sure here.
have you taken the reading of the sensor?
what’s the ambient temp like?
this is a fairly simple fridge, so I’d be having a good look at all the symptoms and then trying to separate the fault from system or control.
another point, I’d always have the fan running on this type of fridge, for a more evenly distributed temperature.
if the fan isn’t running then due to the fact that its a big cabinet, it will be colder at the bottom and the back of the cabinet and warmer at the top and the front.
how are you taking the temp?
