The Liebherr Larder Fridge #0973324-02 will only stay cold if the “super cool” button is pressed. I’m guessing it could be the thermostat (Liebherr #6151178), the Sensor (Liebherr #6942028) or the control board. Any advice would be welcome, the fridge is about 5 years old. TIA, Max
OK I’ve checked the SENSOR with a Multimeter and that is working fine. So it’s probably the Thermostat. The bottom of the Thermostat unit appears to have a small diameter metal gas feed pipe attached, so I’m unsure as to whether I can fit a new thermostat without causing problems with the gas. Surely the Thermostat must be easily replaceable, it’s available aa s spare?
