I have a Liebherr Fridge Freezer cunesf3515-21 and recently the alarm has been sounding and the fridge not working at all. The freezer seems to be fine.
If i leave the fridge door open slightly after turning it off and on again then the fridge frosts up and seems to be constantly working, so id assume the sensor and PCB is working ok?. As soon as i shut the door after an hour or so it gets warm and then doesnt work at all. The evaporator fan seems to be spinning and the compressor is working fine. Any ideas what to check for? Im a real novice but im sure its not something major. It is apporx 8 years old and ive already changed the start relay because i thought that might be faulty.
