Liebherr GN1956 Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr GN1956 Freezer
  • #73878
    Dave CH
    Over the last four years this freezer has occasionally run continuously about four or five times, sometimes resulting in the temperature falling to -32C. Switching off at the mains and restarting after 30 secs or so sorts the problem but it then recurs again some months later. Liebherr understandably will not accept it as a warranty problem so I am left on my own.
    Being an intermittent fault I expect it will be very difficult to pinpoint and I am reluctant to start an expensive part by part replacement program.
    I would very much appreciate any advice on what might be the cause of the problem particularly from anybody who has experienced the same fault.
    #389169
    DrDill
    Re: Liebherr GN1956 Freezer
    Check supercool button is sticking in, sounds like poss board fault if not
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #389170
    Dave CH
    Thanks, DrDill, We did suspect the Superfrost but the SS stars do not show on the indicator when the machine is in fault so I guess the board will have to be replaced. Is this a job I can do, I am OK with electrics but can find no advice on replacement procedure on the web. I would appreciate any advice.
