Liebherr ICBN3366
  • #90661
    slyp98
    Hi guys , ice cube tray was damaged in this fridge I replaced the tray and water enters the tray but it will not dump ice , ice reset several times I also noticed the bucket full lever is stuck in the closed position , I have removed the lever to see if it will reset in the open position but to no avail anyone have any info thanks
    Mod edit: Have added the make to the title 😉
    #445516
    slyp98
    Re: ICBN3366
    9987484-00 service no
    #445517
    slyp98
    Re: Liebherr ICBN3366
    Update icemaker led flashing 3,Times anyone know what error this is thanks
    #445518
    slyp98
    Bump
    #445519
    ELDAR59
    Hi mate, sorry I’ve just seen this. If the icemaker flashes 3 times only, this is indicating the fill time. The factory setting is 3 flashes, on a scale of 1 to 8.
    If this is what you’re finding, then just hold in the little button underneath the flashing led until it goes off or stays on steady.
    If the light flashes all the time, then it could indicate that there’s no magnet in the ice bucket underneath the ice maker.
    The magnet interacts with a reed switch on the icemaker. Without the magnet being in place, then the appliance won’t harvest the ice.
    If there’s no magnet in the ice bucket, try the one alongside it and see if there’s one in that one.
    #445520
    slyp98
    Cheers
    #445521
    ELDAR59
    No worries.
    Another thing to check would be that the icemaker fill tube isn’t blocked up with ice.
    #445522
    slyp98
    cheers , magnet was missing even though customer maintains there never was any there, i just used a piece of old fridge door seal all worked ok just need to find a permanent one now thanks for the help
