Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Liebherr ICN 3066 Fridge Freezer not getting cold
- This topic has 4 replies, 2 voices, and was last updated 6 years, 2 months ago by
Sylar000.
January 31, 2020 at 12:37 pm #97125
Sylar000
ParticipantHey,
Model: ICN 3066
Service Number: 9987022-12Hoping some help diagnosing an issue with my fridge freezer.
A few nights ago I came home to the fridge freezer bleeping which I assume the door wasn’t shut properly and the fridge was not very cold. I managed to stop the bleeping and assumed all would return to normal.
The next morning I noticed that the fridge was even warmer and that the the freezer was also getting warmer. After reading various pieces of advice including on here I fully defrosted the fridge and freezer and left them for 48 hours.
It has been a few hours since turning everything back on and there is no sign that anything is getting cooler.
As it stands the fridge is set to 5 degrees and freezer is set to -18, but it currently shows 17 degrees on the fridge and — on the freezer – see link for video: https://imgur.com/a/RYl9bFk
Update: The fridge freezer has now been back on for 8 hours or so and is showing 18 degrees on the fridge but -7 on the freezer: https://imgur.com/a/3FDFG7q – the water I put in the freezer is now frozen but the fridge is still warm.
Update: Last night it started bleeping again and the freezer had dropped from -18 to -10. I stopped it bleeping and went back to bed. Today the freezer is on -20 despite being set to -18 and the fridge is still on 18 despite being set to 5.
Update: It started bleeping again and the freezer had dropped from -18 to -9 the fridge is still on 18 despite being set to 5.
Appreciate the help, can anyone advise?
Thank you
February 10, 2020 at 3:11 pm #466216Sylar000
ParticipantBumping this as a last chance scenario before I commit to a new Fridge Freezer.
If anyone has any info please let me know.
February 10, 2020 at 4:01 pm #466217Tony R
ParticipantFrom the issues you have mentioned, I cannot advise you on where the fault might be, it needs inspecting by a Liebherr Engineer, it is not that old ie production period Jan 2011 to April 2012, call 0333 0147 888 and they will give you your local Liebherr approved Engineer.
February 10, 2020 at 4:19 pm #466218Sylar000
ParticipantThanks [USER=”46466″]Tony R[/USER]
February 27, 2020 at 11:35 am #466219Sylar000
Participant[USER=”46466″]Tony R[/USER] I have been unable to get a local engineer to come and inspect still! I am tempted to have a go at fixing it myself before I bin it. If you had to guess based on the above description what would you advise I do? Thanks
