Liebherr IKB3650 sensor replacement
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr IKB3650 sensor replacement
  • #90799
    Toonfly
    Hi All
    I have a Liebherr IKB3650 fridge and it appears that the sensor
    https://shop.ukwhitegoods.co.uk/9590142 … zer-sensor
    has malfunctioned and requires replacement, as the fridge is continually icing up.
    Question is….how do I actually replace the sensor? There is no guidance in the users’ guide.
    Many thanks in advance
    ToonFly
    #446023
    Tony R
    Re: Liebherr IKB3650 sensor replacement
    If you are going to fit the 9590142 you will have to remove your unit from the carcase.
    I would advise you to call Liebherr and get a qualified engineer to do it.
    Regards, Tony. http://www.liebherr-randallrefrigeration.co.uk/
