Liebherr K 2330 fridge door problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr K 2330 fridge door problem
  • #98742
    Mike harris
    Hi wonder if. Anyone can help. My fridge has a door closing issue. When the door is very nearly closed there is quite a resistance and a noticeable clunk. ( sorry the technical term) the door occasionally opens and has to be closed again. The fault isn’t always present but does occur say 7 times out of 10. I’ve observed the lower hinge seating whilst closing the door and can’t see any5hing obvious.
    the service number is 0907846_01
    sorry for enquiry I didn’t want to take the door off until I have more info
    #473622
    Tony R
    Hi Mike, The problem maybe the light switch jamming and stopping door from closing smoothly.
    #473623
    Mike harris
    Hi Tony many thanks for your reply.
    ive checked the switch and no problem. The door will close if I lift slightly before closing then athe fridge clunks towards top of fridge. I suspect the upper hinge I’m going to remove the top plastic cover and examine more closely
    thanks again
    #473624
    Tony R
    Hi Mike, there is a torx screw on the face of the bottom hinge, unscrew that and slide the door off with the pin that sits in the lower hinge groove and the bottom of the door, then you can check if the top hinge pin is loose.
    #473625
    Mike harris
    Hi again Tony thanks once more, I’ve see the Torx screw on the bottom hinge with the pin sitting in its slot. I’ll take the door off later today and check upper pin. Thanks once more
