liebherr kes 4260 larder fridge
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries liebherr kes 4260 larder fridge
  • #63028
    slyp98
    hi all , had a look at this , freezing food on lowest setting anyone deal with liebherr , are parts easy to get , any tech info on these please thanks
    #352245
    johnsdad
    Re: liebherr kes 4260 larder fridge
    Evap sensor is common problem, plenty of threads on here
    #352246
    slyp98
    where can parts be got ?
    #352247
    slyp98
    hello again fellas , anyone have tech info for these or what the sensors should be reading thanks
    #352248
    ELDAR59
    hi mate, you need part no 9590142.
    the fridge freezing everything will be the fault of the evap sensor. you could be really unlucky and it could be the pcb, but in terms of probability, it’s going to be the sensor.
    #352249
    slyp98
    hi alf , i checked the control board today , 3 connector blocks on it 2 on one end one on the other next to the stat , the wires next to the stat are blue and red two core white and when tested with a meter i’m getting 14.6k ohms surely this means sensor is working ok ? the other wires are brown and blue 2 core and brown, blue and black 3 core .
    #352250
    ELDAR59
    hello, just seen this message, been really busy this week.
    the sensor wires will be brown and blue with a white insulation.
    assuming you’ve tested the correct wires, then 14.6k ohms would indicate a temperature of just above zero. if it’s freezing everything, then this is a further indication that it’s the sensor at fault.
