I have the following Liebherr table top fridge model:
Model No. KTPES 1750 INDEX 20E
Service No. 9986817-05
Appliance No. 42.851.898.9
The display is showing an F2 fault code and I have had an engineer (booked through this website) visit today to take a look. Although from my searching this appears to be an evaporator sensor fault code the engineer has said he can’t find any sensor on this model and that I will need a new PCB.
Does this sound correct? I just don’t want to spend £s if the new PCB doesn’t fix the issue and I assume a new PCB is more expensive than a new 9590142 Air Sensor kit!
