Service No: 0977216-03
After 10 years faultless service, my fridge has stopped cooling following a powercut. I took Liebherr’s advice and carried out a factory reset but that didn’t resolve the problem….it did cool initially though but didn’t maintain it.
The compressor works as it does click on and run but seems to be intermittent. The evaporator fan spins so that seems ok. The internal light flashes which I believe indicates a cooling failure? So guessing that either the temp sensor, compressor relay or PCB are faulty?
Would really appreciate some advice as must fix this as it matches a side by side larder freezer/wine cooler and to replace both is over £3k!
Cheers
Tony
