Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › liebherr no frost freezer temperature problem
- This topic has 6 replies, 3 voices, and was last updated 9 years, 2 months ago by
eddycowler.
January 22, 2017 at 7:35 pm #90399
eddycowler
Participantcan anybody please help?
I have a SGNes upright freezer and over the last few months the alarm has sounded more and more frequently. Each time I unplug and open the door until the temp is above zero then switch back on and all is ok again but then a few days later the alarm sounds again!
Now the alarm is going off after 15 mins of doing the above. The freezer was emptied, switched off and completely de-frosted for 2 weeks before I replaced the evaporator sensor – the fan is operating, (the freezer still empty) but alarm still goes off almost immediately after switch on. Do you know what the air sensor does and should I re-new this also to eradicate this problem? also..I get the nA sign come up which the booklet said is power failure, although none of the other appliances show this sign (eg liebherr fridge plugged in right next to freezer) i would really appreciate your help in this matter
eddycowlerJanuary 23, 2017 at 12:14 am #444660kwatt
KeymasterRe: liebherr no frost freezer temperature problem
Sensor issue most likely.
But, I’d need the service number to look it up.
January 23, 2017 at 10:09 am #444661eddycowler
ParticipantRe: liebherr no frost freezer temperature problem
Thank you for getting back so quickly. Is that the air sensor you recommend me changing?
service no: 9985242-02
serial no: 24.647.655.3.Eddy
January 23, 2017 at 10:15 am #444662kwatt
There are two in it plus a temp limiter, the limiter will be okay I’d think.
Both sensors are the same, this one:
https://shop.ukwhitegoods.co.uk/9590148 … ure-sensor
Small kit thing now, one mounted at the top and one at the front in the evaporator housing.
What one is the problem though, that I can’t tell you.
January 23, 2017 at 10:22 am #444663eddycowler
many thanks..wish me luck!
January 23, 2017 at 7:03 pm #444664eddycowler
Good Evening K
Unfortunately both sensors have been changed but still getting the nA sign immediately with with alarm after switching on. None of the buttons on the panel respond when pushed..ie the up and down temperature buttons, superfrost and alarm wont stop unless its switched off at the wall..any other ideas would be greatly appreciated!January 26, 2017 at 10:50 pm #444665Tony R
Eddie, do you have a euro plug adapter on the mains plug ?
You are definitely losing power to the unit, hence nA in the display.
It could be a faulty connection in the adapter, there are a couple of slots the pins sit in, they may not be making a good connection. Would suggest fitting a British plug and retest.
Tony.
http://www.liebherr-randallrefrigeration -
