Re: Liebherr premium biofresh 6102 fridge door shelf
Hi rourkes
Google lists a biofresh 6102. However the story doesn’t end there as there is also the SBS6102 and the SBES6102, they maybe the same door parts I don’t know. The model number label can normally be found behind one of the baskets or buckets usually the bottom one.
If you cannot find anything then I would probably email a couple of photos to Liebherr serviceIf you can find the full model number you should be able to order the shelf through the UKW shop by emailing spares@ukwhitegoods.co.uk
HTH 🙂
Don
