Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Liebherr problems
- This topic has 9 replies, 3 voices, and was last updated 9 years, 8 months ago by
kietav.
August 3, 2016 at 1:58 pm #88951
kietav
ParticipantHello, I have a fridge-freezer Liebherr fridge. Last night I didn’t close the freezer door completely, and when I woke up this morning the fridge was beeping, (beeps the same when you don’t close the door for 1 minute). When I opened the fridge the top panel said that freezer’s temperature is 0C, and the fridge’s temperature is 20~C. I changed the temperature of the freezer, and freezer’s temperature light started flashing and going down (the freezer is working), but fridge’s temperature isn’t going down, it’s rising. By the way this happened before, but my dad, came over pressed some buttons and it started flashing and went down. I can’t contact my dad atm 🙁 , so is there anything that I can try to do my self? I tried switching it off and on, I tried switching the power to the fridge on/off, but it doesn’t seem to work. Thanks for your answers.
P.S. Sorry for my English, not a native speaker.EDIT: Model number: ICBN 30560
August 3, 2016 at 2:08 pm #439878kwatt
KeymasterRe: Liebherr problems
Do you have the model or the service number?
It’s possibly blocked up with ice and, if so, you’ll have to shut it down for at least 24 hours to let all that melt away then try it again.
August 3, 2016 at 2:14 pm #439879kietav
ParticipantRe: Liebherr problems
I have some photos and a gif of the problem.
http://imgur.com/a/67q0I
https://gfycat.com/MassiveScrawnyBorderterrierAugust 3, 2016 at 2:24 pm #439880kietav
The model number is ICBN 30560
August 3, 2016 at 2:25 pm #439881kwatt
That doesn’t really help.
Here’s what you need to know to find it, there’s hundreds of models…
https://help.ukwhitegoods.co.uk/support … pare-parts
But, the advice above stands.
August 3, 2016 at 2:30 pm #439882kietav
August 3, 2016 at 3:08 pm #439883kietav
I removed all the stuff from the fridge and put it in the freezer, turned off the fridge, and left the freezer on. Will that work? I really don’t want all the stuff to go bad.
August 3, 2016 at 3:10 pm #439884kwatt
If it’s blocked up with ice as I suspect, the only solution is to completely defrost it. No alternative I’m afraid.
August 3, 2016 at 7:32 pm #439885Tony R
There is a manual defrost setting, but as Ken has already stated we need the correct model and index number, or service number, before we can assist further, you have one two many numbers after ICBN which we know is a built in combination with bio fresh.
http://www.liebherr-randallrefrigeration.co.uk/August 4, 2016 at 2:47 pm #439886kietav
UPDATE: Hi, I turned off the freezer and left it open for a some time and turned it on and left it empty before going to sleep. When I woke up temperatures of Freezer and the fridge were both right. Thanks a lot for your help guys!
