I have a replacement fridge door seal from UK WG for my Liebherr fridge Service Nr 0981094-01 but as far as I can see the door is ‘blown’ in construction – the shell, lining and seal all held together by injected insulation foam which may mean the seal non -replaceable? I can see no way to dismantle the door or pull the seal out – it seems to be firmly attached to the door and prising it away seems too reveal the foam filling the cavity. As the part was available I have assumed there must be a way to replace it but am stumped (also baffled by Liebherr’s instance on ordering a replacement pack of fixing screws as there is not a screw to be found around the seal!)
Any ideas on this? Thanks
