Liebherr Temperature Sensor
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr Temperature Sensor
  • #78777
    Mikeyteach
    My Liebherr Freezer GP 1466 has a problem.
    The freezer seems to be running non-stop but the digital temperature display shows -4ºC. To test the temperature inside the freezer, I put inside the freezer an independent thermometer which showed the the temp. at -28ºC whilst the digital display was still reading -4ºC.
    Anyway I replaced the PCB control board but the problem still persists and I am assuming that the problem might be the temperature sensor. So my question is:
    Before I buy a new sensor is there a way to test the sensor to see if its broken?
    Mike
    #406867
    Re: Liebherr Temperature Sensor
    Explained in this article is the most effective and quick way to check it…
    http://www.ukwhitegoods.co.uk/help/fix- … stors.html
    The Liebherr ones are a thing that seems to cause that sort of error though so I’d be pretty confident assuming that it was faulty.
    Mikeyteach
    Thankyou for your reply and the link. I will try the test.
    Regards
    Mike
