LIEBHERR UPRIGHT FREEZER GN2856
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LIEBHERR UPRIGHT FREEZER GN2856
Viewing 1 post (of 1 total)
  • #55509
    Dan76
    Afternoon all, This one is not always maintaining -18. Temp will bounce up and down because circulation fan will not run but fan will run for around 3 seconds when light switch activated but then stops. I assumed it was a board control faut and changed it aswell as the air temp sensor but it seems as if fan won’t run. Has anyone got any ideas, was thinking of changing fan motor but it does run if only for a few seconds?
    After changing pcb and sensor I ran it up for around 45 mins with door open but switch depressed (taped!) to see if fan would power up but, nowt!
    Any info would be gratefully recieved
