Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Liebherr wine cooler – temp fluctuations
- This topic has 5 replies, 2 voices, and was last updated 6 years, 10 months ago by
AdamPB.
May 14, 2019 at 8:41 am #95864
AdamPB
ParticipantHi all. Hoping someone can help.
I picked up a second hand Liebherr wine cooler (Wtes 1753) on Sunday and temp seems to be fluctuating rapidly.
When first moving it onto the dolly it leaked a little. I transported it on its back (my only option) but tilted. And when home, I let it sit for 3hours before turning on.
With no bottles inside I’ve been running for 24hrs and it moves from 12c to 7c within 20mins and the humidity from 16{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} to 40{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} in the same time. All readings are from a digital temp/humidity gauge with new batteries.
The coolers temp display shows no fluctuation and stays at 14c (the desired temp I set)
https://www.avforums.com/attachments…-jpeg.1150689/
Anyone have any ideas? Thanks in advance!
May 14, 2019 at 5:06 pm #461575Tony R
ParticipantHi Adam, can you supply the index number and service number.
May 14, 2019 at 5:52 pm #461576AdamPB
ParticipantThanks for the reply.
Index No: 20 / 001
Service No: 9983125-00model: wtes 1753
May 15, 2019 at 11:41 am #461577AdamPB
ParticipantHi Tony. As a further update I’ve turned the unit off and vacuumed the air intake in the plinth as per the instructions in the manual. Not sure if this will help.
Thanks.
May 15, 2019 at 3:04 pm #461578Tony R
ParticipantCaused by the construction form and the different operating conditions, a certain divergence between air temperature in the compartment and the displayed temperature cannot be avoided.
However a new integral power board was produced for this model up to index 21C, but I cannot find it as a spare available now, your unit was produced in 2005.May 15, 2019 at 6:35 pm #461579AdamPB
ParticipantThanks tony. Are you saying it’s failing because it’s multi temp? (when you state “different conditions” and “construction form”) just struggling to understand the diagnosis in simple terms 🙂
So if the power board has failed and there’s no spares in production anymore, would a newer PB be compatible? If not, any other options?
