Lifespan of Bosch door seals?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Lifespan of Bosch door seals?
  • #67638
    clive45
    How long might one of these last before starting to leak?
    I have a Classixx 6 1200 which is just coming up to 2 years old.
    There is a small build up of limescale on the bottom of the door glass which looks like it allowed water to leak out today. I have cleaned it off and I’m using the machine again to see what happens.
    As the 2 year warranty is nearly up I want to let Bosch know if I have a problem asap.
    Any comments would be appreciated.
    #368064
    Re: Lifespan of Bosch door seals?
    It depends on the conditions, how much washing you do, what you wash and what you wash it with TBH.
    Different circumstances make it nigh on impossible to give a lifespan in weeks, months or years with any part.
    Re: Re: Lifespan of Bosch door seals?
    clive45 wrote:There is a small build up of limescale on the bottom of the door glass which looks like it allowed water to leak out today. I have cleaned it off and I’m using the machine again to see what happens.
    Golden rule to ensure you never have door seal problem = wipe clean the rubber (especially the inside folds) after every wash session. Wipe the door glass, also and wherever practical, leave the door ajar slightly to allow good ventilation avoiding bacteria build-up!
