Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Light inside siemans fridge freezer
- This topic has 19 replies, 4 voices, and was last updated 18 years, 2 months ago by
teresagreen.
January 15, 2008 at 11:58 pm #33725
teresagreen
ParticipantThe light inside the fridge is flickering?Does it just need a new bulb?
January 16, 2008 at 12:01 am #239789gegsy
ParticipantRe: Light inside siemans fridge freezer
Model?
January 19, 2008 at 4:56 pm #239790teresagreen
On the front it says Vario Electronic.
January 19, 2008 at 5:10 pm #239791gegsy
Its usually on the wall inner near the salad trays.
If its a normal bulb it may need screwing down a little more or the prong of the bulb holder which touches the centre of the bulb may need teasing forward. WITH THE APPLIANCE UNPLUGGED FIRST :plug:Greg
January 19, 2008 at 7:46 pm #239792teresagreen
thanks-i will go and look now.So is the bulb likely to be a bayonet cap? I have tried to loosen it (with the fridge off) but its not moving.
January 19, 2008 at 7:50 pm #239793teresagreen
is it KGV3104
also KGVIV04GB/06January 19, 2008 at 8:29 pm #239794gegsy
The numbers are similar but not fully coming up 😕
Nevertheless, it is a screw in bulb so it sghould come ot with a ant-clockwise turn. Jus be careful t doesnt break and cut you ❗Greg
January 19, 2008 at 8:34 pm #239795teresagreen
I do need to be careful because it isnt moving.I am defrosting it overnight-I think I will try it again when it is completely dry-any other tips how to loosen it then?Wd 40?
January 19, 2008 at 8:36 pm #239796teresagreen
Or sf-31/KGVA?
January 19, 2008 at 10:02 pm #239797nomadPaul
ParticipantDoes the lamp flicker with the door open or is it when you cheat/close the door ? Is there a little switch on the side of the lamp housing ? If there is , is it showing a red segment ? If present , this may be a winter switch which will keep the lamp on at roughly 30{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} with the door closed – Try switching this switch off if its present .
January 19, 2008 at 10:20 pm #239798teresagreen
I cant tell if it flickers when I close the door!
January 19, 2008 at 10:22 pm #239799teresagreen
No there is no switch.I thought i had fixed it then-i switched it on again and it had stopped flickering-i switched it off and fitted the housing cover-then it started flickering again.grr..
If i look at where the bulb goes in,there seems to be a seal round it-a bit like a rubber seal.January 20, 2008 at 10:28 pm #239800superfix
It will more than likely need a new door s/w.
The contacts tend to “soot” up on them.
Power off please if having a go :zap:
January 30, 2008 at 7:34 pm #239801teresagreen
Anything else I can do to “clean it” first?
January 30, 2008 at 7:55 pm #239802gegsy
teresagreen wrote:Anything else I can do to “clean it” first?
Not really and TBH its pretty in expensive 😉
Taking the model as KGV3104GB/01 as thats the nearest I can come up with, the light switch is 067747 app £8 Plus the usual.
A click to shop@ on the left hand side will get you sorted.Greg
