Light inside siemans fridge freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Light inside siemans fridge freezer
Viewing 15 posts - 1 through 15 (of 20 total)
  • #33725
    teresagreen
    The light inside the fridge is flickering?Does it just need a new bulb?
    #239789
    gegsy
    Re: Light inside siemans fridge freezer
    Model?
    teresagreen
    On the front it says Vario Electronic.
    #239791
    gegsy
    Its usually on the wall inner near the salad trays.
    If its a normal bulb it may need screwing down a little more or the prong of the bulb holder which touches the centre of the bulb may need teasing forward. WITH THE APPLIANCE UNPLUGGED FIRST :plug:
    teresagreen
    thanks-i will go and look now.So is the bulb likely to be a bayonet cap? I have tried to loosen it (with the fridge off) but its not moving.
    #239793
    teresagreen
    is it KGV3104
    also KGVIV04GB/06
    #239794
    gegsy
    The numbers are similar but not fully coming up 😕
    Nevertheless, it is a screw in bulb so it sghould come ot with a ant-clockwise turn. Jus be careful t doesnt break and cut you ❗
    teresagreen
    I do need to be careful because it isnt moving.I am defrosting it overnight-I think I will try it again when it is completely dry-any other tips how to loosen it then?Wd 40?
    #239796
    teresagreen
    Or sf-31/KGVA?
    #239797
    nomadPaul
    Does the lamp flicker with the door open or is it when you cheat/close the door ? Is there a little switch on the side of the lamp housing ? If there is , is it showing a red segment ? If present , this may be a winter switch which will keep the lamp on at roughly 30{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} with the door closed – Try switching this switch off if its present .
    #239798
    teresagreen
    I cant tell if it flickers when I close the door!
    #239799
    teresagreen
    No there is no switch.I thought i had fixed it then-i switched it on again and it had stopped flickering-i switched it off and fitted the housing cover-then it started flickering again.grr..
    If i look at where the bulb goes in,there seems to be a seal round it-a bit like a rubber seal.
    #239800
    superfix
    It will more than likely need a new door s/w.
    The contacts tend to “soot” up on them.
    Power off please if having a go :zap:
    #239801
    teresagreen
    Anything else I can do to “clean it” first?
    #239802
    gegsy
    teresagreen wrote:Anything else I can do to “clean it” first?
    Not really and TBH its pretty in expensive 😉
    Taking the model as KGV3104GB/01 as thats the nearest I can come up with, the light switch is 067747 app £8 Plus the usual.
    A click to shop@ on the left hand side will get you sorted.
