Light switch?
  • #77588
    Slimmy6828
    Hi, I have a Nardi nr72ro fridge freezer, as per the below link. The fridge light bulb recently stopped working so I replaced it but it still doesn’t work. The problem I have is that I cannot locate the switch to see if that has failed. Any advice as to its location and how to remove it would be appreciated, thank you
    http://www.ebay.co.uk/itm/NARDI-NR72RO- … 1180269813
    #402685
    ELDAR59
    Re: Light switch?
    I’m not familiar with that model, but if you can’t see the switch then there’s probably a magnet in the door that interacts with a reed switch in the body of the fridge.
    I’d be looking at the terminals in the lamp holder, making sure that when the bulb is in place, one terminal touches the bottom of the bulb and one touches the side.
    #402686
    Slimmy6828
    Re: Light switch?
    Thanks for the advice. Have just blown another bulb so there must be a bad connection somewhere….
