Lights in John Lewis JLSS2009
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Lights in John Lewis JLSS2009
  • #92509
    Dr Pepper
    I have a John Lewis JLSS2009 and the cooling and freezers are functioning fine, however, when I open the Fridge door neither of the lights are coming on. If I switch the Fridge off and back on when I open the fridge door both lights come on. They stay on though, so when I shut the door they remain on. After about 10 minutes they switch off and don’t come back on when I open the door, again they work briefly after a power reset. Any thoughts?
    #451483
    SAMURI
    Re: Lights in John Lewis JLSS2009
    The door on the fridge may have dropped so it is not operating the light switch.
    The light then cuts out on the thermal cutout and only comes back on after a reset.
    The door will have to be raised with some nylon washers on the hinge pin.
    Bob
    #451484
    Dr Pepper
    Thanks Bob, is the light control likely to be the white piece where the doors meet?
    #451485
    SAMURI
    John Lewis models work with a magnet built into the door on the top.
    If you reset the light so it’s on then with the fridge door open use a magnet just underneath the display panel and move from side to side near the centre and you should see the light go out.
    Bob
    #451486
    Dr Pepper
    Thanks again
