Like for Like replacement Washer Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Like for Like replacement Washer Dryer
  • #85939
    WelshDragon1
    Hi Guys & Girls
    Long story, not getting too much into it, but Landlords (NICEIC electrician) stuffed it up by not unplugging it during a full electric test procedure (despite knowing the plug should of been unplugged) have attempted repairs, but according to the outsourced firm, parts are not available anymore..
    The Washer Dryer (Condenser) to be replaced is an Ariston Margherita AWD 12 Advantage (http://imagebank.indesitcompany.co.uk/b … /A1435.pdf)
    Can anyone advise what is the upto date equivalent & possibly the best places to get one from.
    No expense spared as Landlord is paying…… that said in case Landlord falls through all price ranges will be considered from budget upwards…..
    Please note:
    It has to be like for like or as near as is possible
    Separates are not a viable option due to size & shape of kitchen
    Thank you in advance
    #429860
    don
    Re: Like for Like replacement Washer Dryer
    Freestanding washer dryers are a low volume affair, most manufacturers produce one or two so the choice is limited which is a good thing when choosing.
    If budget is not the issue then the Miele is the only one which gets anywhere near to doing a good job. After that I would look at the Bosch, Aeg and Zanuusi’s, Hotpoint, Hoover and Candy’s then the rest.
    To get started the supplier with the largest range to compare all on one site in the UK is AO selection here
    Don
    #429861
    WelshDragon1
    Thank you don
    I really need help to narrow it down to a known reliable WD 😉
    Welshdragon1
    #429862
    don
    don wrote:
    If budget is not the issue then the Miele is the only one which gets anywhere near to doing a good job. 😉
    Don
