lime scale
  • #51049
    frustin
    we did a woolen wash @ 40degrees, in our “AEG OKO_Lavamat 74620 update” (it’s about 7 years old), this morning and when the cycle finished we found a load of flecks of lime scale in the washing.
    we put it back in at a normal wash (not woolen) @ 40degrees and that cleaned it with no lime.
    i’m wondering if this is a co-incedence but recently (the last month) the drain pipe has started it over flow. basically the drain pipe feeds into the cupboard into a vertical pipe (plastic) that goes down into a U-bend and off to the drain. I’ve managed to fix most of it using caustic soda a few times to clear the drain, but i’m still seeing some suds build up around the top of the vertical pipe when the machine is going through a cycle.
    Is there anythign i can do about this? or is my machine on its way out?
    #306731
    TheSpinDoctor
    Re: lime scale
    Hi.
    You might want to periodically run a cotton boil wash without laundry with half a measure of a quality brand biological powder based detergent & clean the filter afterwards.
    Worth a shot.
