Liqui-tabs
  • #79587
    hotpoint9506
    I am hoping a washer engineer can answer this.
    Are those liquid-tabs made out of plastic? I hear various things from different people and some say they are bad for washing machines whilst others say they are fine.
    Another thing is how does dissolved liquid cling to the insides of a washing machine when in theory its a dissolved solution?
    #409877
    Re: Liqui-tabs
    It is a form of plastic, I think, that is dissolvable.
    The makers aren’t exactly forthcoming with the trade secrets of how they do that or what it’s made from but, it does completely dissolve.
    Reading this article will help to begin explaining the rest…
    http://www.ukwhitegoods.co.uk/help/clea … gents.html
    hotpoint9506
    Re: Liqui-tabs
    Very informative article thanks. Now I know the tabs are made of plastic I don’t think I will use them. Will stick to powder mostly.
    #409879
    Re: Liqui-tabs
    I have seen the slimy plastic residue from these satchets stuck all over the inside of door seals on the odd occasion.
    The real problem with them in very soft water areas like we have here is that you cannot reduce the dosage and in many cases even one capsule is far too much.
    #409880
    hotpoint9506
    Re: Liqui-tabs
    I had to add water to the machine just to dissolve the sachet. I find even in hard water one sachet is too much for normal soiled clothing. Have been rinsing for eternity!!
    I often wonder though where the dissolved sachet goes and whether it does lurk in the drain hose.
    #409881
    Andy jones
    Re: Liqui-tabs
    Hate these things. Quite often end up with that gungy sachet all over my hands. Yuk
    #409882
    Re: Liqui-tabs
    http://www.ariel.co.uk/faq/why_is_there … cycle.aspx
    Overloading or general use basically.
    Used correctly, there should be no problem.
    Andy jones
    Re: Liqui-tabs
    I don’t use them btw. Can’t beat good old fashioned powder
    #409884
    Re: Liqui-tabs
    kwatt wrote:It is a form of plastic, I think, that is dissolvable.
    No mystery, it’s just gelatin.
    #409885
    Re: Liqui-tabs
    Uhm, I’ll think you will find that it isn’t.
    Re: Liqui-tabs
    The men in white coats at P & G would confirm no doubt.
