There is also a channel on there called, unsurprisingly, #thewarroom!
It is done by invitation *only*, you cannot access it without having an invite to the channel. To get that simply PM me using the following command in the channel window:
/msg Lynchpin hello
Which will open a private chat session (you can use that with other users, simply change the username to the one you wish to talk to) with me and if I’m about I will do the old “invite” thing for you. I will try to find out if I can set permanent permissions for you guys to get access without the need for that crap.
You can sit there for as long as you like logged in, but you cannot run multiple instances from the site Java client.
