Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Load & Unload Issue
- This topic has 8 replies, 5 voices, and was last updated 8 years, 3 months ago by
Jambo1981.
January 2, 2018 at 12:19 pm #92955
Jambo1981
ParticipantI have an integrated Indesit washer dryer.
It has started to load and unload on every cycle so does not now wash or dry anything.Can’t afford to get anyone out to look at this. Can anyone help?
Regards
JamesJanuary 2, 2018 at 12:45 pm #452697electrofix
ModeratorRe: Load & Unload Issue
not sure what you mean. when I load a washer I physically open the door and put my washing in and close it
what do you mean ?
January 2, 2018 at 1:42 pm #452698don
Jambo1981 wrote:I have an integrated Indesit washer dryer.
Regards
JamesJust guessing is it filling and draining at the same time??
Moved you to washing machine repair forum 🙂
Don
January 2, 2018 at 3:58 pm #452699Jambo1981
ParticipantRe: Load & Unload Issue
Possibly. If I try one of the programs the content of machine do not even get wet.
I can get water in by putting the machine on rinse then i spin them about 10 times to get as much water off them as I can and then have to air dry.
Any pre set programs no water makes it way to the drum so i get all the noise for a few minutes but that’s it.
Found something in book about the waste pipe being between certain heights but that looks to be fine.January 3, 2018 at 8:51 am #452700Martin
It could be heating element problems. I wonder if James could enlighten us with the model number of his machine as that may help?
Oh! And just to clarify his take on “loading & unloading”? Does he mean ‘filling then draining?’
January 3, 2018 at 1:13 pm #452701Jambo1981
Will check on number tonight as in work currently. Did have it on phone but that’s died too…
Yes filling and draining, only the programs (except rinse) don’t actually fill the machine. its all talk (noise) and no action
January 3, 2018 at 3:26 pm #452702iadom
Model number is essential, some machines are hot and cold fill, more recent ones cold fill only. A faulty hot fill valve could cause this problem, especially if you have a combi boiler. It will sound as though it is filling but if you look in the detergent drawer you may just see a trickle at the back. Could also be main pcb failure, very flakey on these, drain pump energised at the wrong time one of many known faults. 🙁
Are you getting any lights flashing?
January 4, 2018 at 9:53 am #452703Jambo1981
Machine is an Indesit IWDE12
S/N 804158575 *80523900000Yes all the lights flash when it finishes but it always has done, even when it was working.
January 9, 2018 at 12:13 pm #452704Jambo1981
Does the above model number and info give anyone any further clues?
