Loadster gas T/D bitten more than I cld chew
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Loadster gas T/D bitten more than I cld chew
  • #13748
    Mark1
    Thought I would go and try some commercial for a change. When I got there the machine was dead and a strong smell of gas. The thing is 6ft tall and 3ft wide but only 240v. Got a corgi guy to repair the gas leak and rewired up the motor. All tickety boo. Now the thing has a pilot light but wont burst into flame so to speak. Is this controlled by an electric stat or is to do with the gas side. Thought some of you gas guys might know. It was an interesting one and a change for me. Like to see it through if I could. A long shot, any takers or should I pass it to the commercial boys?
    Many thanks
    Mark 😳
    #156436
    chezza
    Re: Loadster gas T/D bitten more than I cld chew
    there is an air flow switch ( micro switch with a disc and wire frame work ) fitted near the burner box, designed to prevent the gas valve opening in the event of a duct blockage, or prevent flare up if the door is opened ( check the filter is clean and the filter door is closed properly )
    on no account should this be taped closed, or shorted, but for testing purposes, hold the disc in while the unit is running and watch.
    if the dryer has a pilot , it is very old and may have faults with the gas valve. any work on the gas side of this should only be done by someone with commercial laundry corgi card.
    regards eddie
    #156437
    Mark1
    Yes it is old and does have a pilot light. I’m pretty sure the electrics are ok but I will double check tomorrow, then pass it over to the corgi guy.
    Thanks for that Eddie
    Mark 🙂
