I have a Homark Colonial oven Model # 01-7600B. The concentional oven works fine (lots of heat ) but if I turn it to use it with the fan (convection oven ) the is no heat. The manual says to check the fuse if there is a problem. If this is due to a burnt out fuse, could someone please tell me where the fuse is located? It is not on the back of the oven, nor does it seem to be inside.
You will find that the fan oven element has failed in the oven if you are trying to use the fan oven setting,the thermostat will be ok due to you being able to use conventional oven,the fuse stated will be the main fuse in the plug which you can disregard as the oven is funtioning in some way.
the element willbe available from dave conway or the on line shop
