Re: Lofra MXUD66AMFE main oven
If you mean a 120 clockwork timer is fitted rather than a digital timer, then these are prone to failure.
When the clockwork timer fails, it kills the power to the main oven elements, a bit like a fuse. Small oven remains serviceable.
Your first port of call is to test the timer, with the power disconnected.
If you are unsure of how to test the timer, get a professional in.
All parts for this unit are still available if needed from us at sales@lofra-uk (dot) co (dot) uk
Regards
Jackal
