Logic w/m
  • #91272
    kaibart
    Hi all I’ve been back and foe to this logic L612wm12 for it leaking every time I go there I can’t see a problem I’ve tried it on a few different washes and stayed no leak. This is what I’ve changed door seal dispenser complete,and most recently I’ve changed the bearings including the tub seal, all I’ve ever seen is the customer over dosing as there where suds coming out of the powder draw and door,anybody got any ideas? Thanks in advance kai 😮
    #447606
    Re: Logic w/m
    You probably answered your own question in your last sentence?
    #447607
    funkyboogy
    Re: Logic w/m
    i would uplift and take to workshop if youve got one
    not known for leaks tbh — but they are one of china’s finest
    ally
    #447608
    timdowning
    Re: Logic w/m
    Daz hand wash powder is an old favourite…
    #447609
    Simon46
    Re: Logic w/m
    Or soap flakes or putting the liquitab in the dispenser instead of drum.
    #447610
    kaibart
    Re: Logic w/m
    Customer is adamant there is a leak from underneath the machine and only happens on certain programmes this has been run in the workshop 7 times on different programmes and I’ve stayed in the house and watched it through 2 15 min programmes without a leak I think customer is trying it on to get a exchange.
    #447611
    EFS
    Re: Logic w/m
    Not wishing to seem to be teaching grandmother how to suck eggs but is the standpipe overflowing when the machine is draining?
    Steve
    #447612
    timdowning
    Re: Logic w/m
    The problem is now you have changed so many parts you are kind of admitting there is a problem but it cant be resolved.
    Unless I see a definite leak I never change parts even if you think they may be the culprit as you may cause a leak when changing the suspected part. Also you waste a lot of time & money trying to convince the customer…
    #447613
    kaibart
    Re: Logic w/m
    Have watched that there are 2 standpipes behind machine 1 which is trapped and 1 which isn’t advised customer to leave pipe in the trapped standpipe.
    #447614
    Re: Logic w/m
    I reckon Steve has it sussed.
    #447615
    Simon46
    Re: Logic w/m
    Eck. Is there a gas meter below that?
