Logik Cooker Hood
  • #90499
    Coker
    Hello
    The Logik Cooker Hood come in a sequence of L60CHDG13, L60CHDG14.
    I have a Logik L60CHDG13 Hooker Hood. I need to get an Outlet Flap. Can anyone tell me if the Outlet flap on the L60CHDG14 is the same dimension as the 13. The diameter is approx. 117mm. (2X Photos) A photo of the Flap, and a photo of its place on the cooker is attached.
    Note the locating slots on Outlet Flap, and its position on the cooker hood.
    Thank you.
    Coker :waving:
    #445000
    Re: Logik Cooker Hood
    Getting info for logic products is about as easy as getting an audience with the pope.
    what is wrong with the flap as they seldom fail. there job is to stop air coming back the other way so unless it is vented to outside its not really needed
    Coker
    Hi Dave
    Thank you for your reply. Quite right about Logik and the Pope.
    The assembly was taken from another site and the Flap got lost. Well, I intended to fit the Flap on the Main Hood Unit, then fit the chimney and lead it to the outside wall.
    But I would also need to get an adaptor plate to fit between the chimney and the hose going to the wall. Subject to your further response, any idea if the Flap is interchangeable between those two models?.
    Because of my background I know that sometimes spare parts can be used on different models of a product. But I do not think I could get those Logik people to do any cross reference for me.
    Coker
    #445002
    no idea if it will fot but if you fit an outside vent cover with flaps on it it should stop reverse flow
