Logik fridge not cooling. LUL55S12 Starts to turn on, then clicks off. please help
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Logik fridge not cooling. LUL55S12 Starts to turn on, then clicks off. please help
  • #97457
    bloodyfridge
    hi, can some one please advise me on how to find and clean the coils, and where the start relay is and how to check it, and anything else to try checking. the back of the fridge is mostly covered. thank you for your help, i’d rather not have some one come into the house to fix it, so would rather try myself first. the fridge is a couple years old. it’s not cooling at all. thank you 🙂
    #467867
    from what you are saying the following happens
    you turn on
    you can hear the compressor start but about 10 secs or less later there is a click and it stops
    if you wait a while the compressor starts up but again 10 secs or so later it stops
    if above is the case then you have a compressor or starter issue. this may be a faulty starter but more often than not its a faulty compressor. If the compressor has failed then you need a new fridge
    the only way you can find out which is to fit a new start relay. A proffessional would carry test components he can plug in to test and remove again. If you did it you are dealing with a make that is not easy for sprares at the baes of times
    hopefully one of the fridge engineers will add to this the likleyhood of the compressor being the fault
    SAMURI
    I agree with Dave it sounds like the compressor is faulty time for a new fridge.
    Bob
