Logik LBFAN X12 won’t heat up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Logik LBFAN X12 won’t heat up
  • #85562
    Brianmassen
    Hi can someone help me please? I have a Logik fan/grill oven LBFAN X12. Fan works but neithe the grill or oven will heat up and the lights won’t work either. What could it be? Thanks for your help in advance.
    #428885
    Notagain
    Re: Logik LBFAN X12 won’t heat up
    Hi, I have the same problem, but as I see you have no replays did you get the oven resolved.
    Thanks, Tony
    #428886
    I’m not familiar with the brand but it could be a faulty limit switch (Thermal Overload Cutout)…? Normally attached on or close to the inner oven lining. It could also be a fault with the main selector switch? Either way it’s power off before investigating. :plug: :plug:
    #428887
    Notagain
    Hi, thanks for your quick response, I’ll take a look tomorrow but, how do I check a thermal cutout?
    #428888
    It’s a simple switch, one wire in the other out. For it to test out OK you should have continuity through the switch as it is normally closed. If the contacts are open circuit the switch is faulty and needs replacing. (They are not usually resettable)
